bleedblue94
1983 johnson 175 idle issue
New to me. I've had it for about 3 months and since I've had it I have had a consistent issue at idle. At first I suspected a lean sneeze, so I took the carbs apart and rebuilt them all, replaced all the recirculation valves which were all bad, and upgraded the fuel lines. Runs very well but at idle it misses and eventually dies out. ever so often the motor will bog when i punch it coming out of the hole. if it does so i simply back off it and then hit the throttle again and the motor will take off. at WOT it runs well and pushes the boat at 40mph. at times i do think i hear a very sporadic miss when above idle, but im not sure if its just my ears playing tricks on me
after cleaning the carbs and replacing both fuel pumps and upgrading all lines the motor still has a miss, but it does not seem to sneeze the way it use to. i think it may be more of an ignition miss. one reason im leaning this way is the motor does not level out when the choke/fuel solenoid is used, instead it dies out (I'm assuming the motor is drowning out on fuel). if the condition that is causing my issue were a lean condition, i would suspect that using the choke/fuel solenoid would help the condition by adding more fuel to level the lean condition. bc it drowns the motor out i am leaning towards a timing or ignition issue. any help would be appreciated.
i removed all the plug wires and found almost all twelve of the end connectors were covered in rust. i cleaned each one and removed the rust just to see if it would help and it almost seemed the motor ran worse. ha. i know that these will have to be replaced soon, but they did not seem to be the cause of the issue i described above. i do have a spark gap tool and plan to test the spark soon. all plugs appear to be firing as none are wet, however they all have some amount of oil deposits on them (i use gap-less plugs); i do mix at 50:1 ratio. im beginning to wonder if this is a link and sync issue, but do not have any information on the proper procedure for this motor. perhaps i am going the wrong direction but can someone give some advice and/or provide the sync procedure for THIS motor. thanks
J175txctd
J175txctd
