Engine will not start unless choked then will run only 2-3 seconds at both idle and W.O.T.
Ran fine until it started losing rpms. Replaced stator, flywheel, fuel pump and diafram. Timing tdc checks with flywheel mark. This engine Does not have a yellow/black wire going to any kill switch and I can't find any other "kill switch" on it. Fresh fuel 50/1, carbs cleaned and float drop is 1 inch. 3/4 inch spark on all plugs
Thanks in advance for any help!
