1983 evinrude 140
jrp65
"I had the boat out all day an
"I had the boat out all day and ran it pretty hard. Then all of a sudden it seemed like it was running out of gas and was losing power. it died and didn't want to start so i got it towed to shore.took off shroud and the flywheel felt hot. any ideas? Also will a 140943R which i think is a 1979 lower unit fit my 1983 e140TRLCTE? Any info please email me at [email protected]. Thanks"
"u need to ck out the eng...
spark'
compression
fuel delivery--tank,filters,fuel pump,carbs..etc
I believe,the 79 will fit your 83...but always dbl ck.."
"Remove all spark plugs and co
"Remove all spark plugs and connect the plug wires to the tester you have, or build the following one.
(Spark Tester - Home Made)
(J. Reeves)
A spark tester can be made with a piece of 1x4 or 1x6, drive a few finishing nails through it, then bend the pointed ends at a right angle. You can then adjust the gap by simply twisting the nail(s). Solder a spark plug wire to one which you can connect to the spark plug boots, and a ground wire of some kind to the other to connect to the powerhead somewhere. Use small alligator clips on the other end of the wires to connect to ground and to the spark plug connector that exists inside of the rubber plug boot.
Using the above, one could easily build a spark tester whereas they could connect 2, 4, 6, or 8 cylinders all at one time. The ground nail being straight up, the others being bent, aimed at the ground nail. A typical 4 cylinder tester follows:
..........X1..........X2
.................X..(grd)
..........X3..........X4
Thousands of parts in my remaining stock. Not able to list them all. Let me know what you need and I'll look it up for you. Visit my eBay store at:
