Blackie323
Hello all.
I have just serviced my 1983 evinrude outboard model #e90TLTCE.(the first time i have done so, im learning as i go). I dropped the lower unit to change the impellar and during that time managed to unknowingly lose the correct height of the shift linkage. After re assembly i determined i must have done this, as while the engine ran up good, sounded good and had a good tell-tail, when i put it in gear the prop was not spinning, however spins well in reverse. It spins as i push the throttle further down in the forward position. Am i right in thinking i have altered the shift linkage height? If so anyone out there know the correct height it should be? I have not yet pulled the unit back apart yet just did a bit of research and thought a forum might help. Thankyou to everyone who takes the time to help me out.
Cheers,
Sam from New Zealand.
Cheers,
