jeffasmith
Guys, Here is the story and I need help: Fired up the motor after winter storage, ran great after the fogging oil burned off. Stopped and started like clockwork. Since the carbs would leak every time I tilted the motor up, I deciede to rebuild the carbs. Installed the rebuilt carbs primed it, fired up after a few seconds of cranking, backed off of the warm up lever, found it was idling higher than before and noted that the roller cam is no longer touching the plate, manually rotated the carb linkage back to get down to idle (how do I fix that?). When I went to shut it off it kept running with the key turned off then I pulled the lanyard and it still kept running. Fortunately, The carb cover was still off so I had to manually choke of two of the three carbs to get it to stall. Anyone every seen this happen. I can't see how the rebuilding of the carbs could cause an electrical iginition failure. I had the battery disconnect all the time while working on the motor. Baffled!!! Help is much appreciated.
Thanks, Jeff
Thanks, Jeff
