1983 70 HP 3 cylinder timing
tthomp1334
What is the correct timing on a mercury 1983 70 HP 3 cylinder at idle
And how to you check the RPM on the engine.
Milton
What is the correct timing on a mercury 1983 70 HP 3 cylinder at idle.
Here we go again... It's NOT a car engine! Just time it at WOT and go boating.
With a tach!
Jeff
With a tach!
Jeff
That is great to know, Now what should the timing be at WOT. ???
Milton
I use about 21 degrees BTDC on mine thanks to lower gas quality. Remove the cam lever on the top carb so you can hold her wide open (about 3 grand).
Jeff
Jeff
Thanks for the post.
Just found the right timing marked on the flywheel, 23 degrees before top dead center.
Milton
