Nice Dreams
Hi all my name is Chris I have a 1983 Chris Craft Catalina 251, with the mallory ignition. A few weeks ago I went down to the boat to run it and it started but was surging a few hundred rpms, and would not idle. When i brought the throttle down to idle it would stall and blow the ignition fuse at the key. I cleaned all the terminals on the coil, and distributor. At this point the fuse stopped blowing but the engine still would not idle and would not even stop when i turned off the key. Upon further inspection I found oil seeping out of the coil. So I got a new coil, points, cap rotor, condenser. I installed the coil first hoping that that was the problem, I mainly just bought the other parts as a precaution. Its been a while since any of them have been replaced and they looked to be due for replacement. After replacing just the coil it would not start. It was firing off but would not start and run. I then replaced the cap, rotor, points, and condenser. Still nothing. The last thing I changed was the ballast resister(which was looking pretty shabby as well) and still nothing. Im at the end of the line at this point and am not sure what to do now. If anyone can shed some light on my situation it would be greatly appreciated. Its starting to get cold here in Jersey and I need to make arrangements to get this boat moving, hauled and winterized. Thanks in advance for any help i can get.
