I have a 1983 Johnson 2 HP that runs great but does not pump any water. The head got too hot to touch so I shut it off. I took off the lower unit and the impeller was in good shape with no cracks, the water pump was in good shape too and was not plugged. I put it all back together making sure the water tube was in the water pump. Still doesn't pump water so I pulled the powerhead off and made sure the water tube was not plugged at it was not. I blew air through the intake and it came out another hole which is where the water exits. The seal was in good shape and nothing being plugged from what I could see. I run it in a bucket with the water level being about 3 inches above the water pump.
Any ideas of what is going on?
Thanks.
Thanks.
