kountzelightdiesel
I have a 1983 OMC 2.5L sterndrive the boat was a wreck when I got it set up for too many years outside after rebuilding the boat I ran it for one ski season. I have a complaint but not serious enough to do anything about till I'm getting ready for this season.
I have not been into the carb yet and it appears to have original fuel pump I tuned it up before last season.
Ok the problem the hole shot from 120 hp should be a little faster. On plane at WOT is 4400 trimmed down all the way up it will run a little over 4600 so prop pitch should be right where I need to be. At idle if you hit it the engine will rev to around 3000 until the boat is completely on plane.
Is there anyway to increase midrange power on these little engines without killing the top end? And any ideas on how to tell if thats just how it is or if it is low power? Projects this season will be to convert to elec. ign. and rebuild the carb. What about the mech. advance in the distributor? Any thoughts will be appreciated.
Thanks Jeff
Thanks Jeff
