kenny_cobb
"Took boat to lake and it had
"Took boat to lake and it had been running good for years. It is mounted on Ranger 330-V. All of a sudden boat did not want to plane off and had miss in engine which appeared to be from firing. It would jump back and forth at full throttle trying to plane off and finally would. Once I got boat home I decided first to put kits in all there carbs. I live on lake so backed boat down and tried out after cleaning carbs. No change. I then decided to check compression and all cylinders are strong. I went on to change both power packs, trigger, and stator. Also changed fuel pump. No change in running. Still bogging taking off and may or may-not finally rev up. What is there left to change. Also I checked plugs with engine idling and timing light hooked to each plug and each is firing at low speed. Would rectifier play part of issue or do you have any other ideas. Thanks in advance for your help. Kenny"
