J
jasonsolar
Guest
"1983 150 evinrude, # 2 cylind
"1983 150 evinrude, # 2 cylinder has low compression (60lbs.) the other 5 have 90lbs. compression. The sealing ring on the head gasket on the #1 cylinder is bad. The gasket is busted between the #1 & #2 cylinders. If the sealing ring is broken on the #1 why is the bad? Could I have stuck rings or could the compression on the #1 be going through the broken gasket giving it an ok compression reading? Thanks for any advice."
