Re: OMC 800 wont pickup water
cobra is a different dog altogether.
Bear with me as in my own inept way in describing the way the water gets to the motor. Reason i stated motor cause your problem may be a blockage there.
Look at the drive lower unit, see the inlets where the water enters the lower. Is there a blockage there, say you ingested seaweed, or a plastic garbage bag or some other garbage.
With the lower off look down the channels, see there are no tubes as in a cobra or earlier stringer drive. This is one of the reasons i am loath to get rid of my 86' stringer and i am babying it along.
The water enters the lower travels up the channels, and enters the water pump in the upper. You know this already cause you did the water pump. The thru bolts must be sealed on the pump, the water pump as per the manual seloc # 3400 right hand corner would explain it better,see where the pump meets the housing you had to seal that also as well as the lip and the cover of the pump. If you missed any of that then you will loose suction hence no peeing on the ball gears.
You can use a water hose and back flush at this point to see if you can flush out the channels and the inlets.
Water travels up the channels to the pivot caps does a u turn thru the trunnion the starboard side has the pee hole on the ball gear. Water then enters the intermediate channel to the hose inside the transom. That long hose can do one of 2 things, it can go directly to the t-stat housing or go to a heat exchanger. Then to the t-stat housing.
Say it goes to a heat exchanger such as a power steering cooler, it can be clogged up.
So say you got that lower back together and the drive back on and you pulled the cap on the trunnion starboard side, and cleared it of any obstruction "it has 4 screws holding it on " and you pull the long hose off where ever it goes to first and hold it straight up and with water going to the drive you start the motor and have water shooting straight up maybe 10-12 inch's then you know you have good water to whatever point that long hose goes. You need only 3-5 seconds and then quick shut off the motor.
Say you pulled the trunnion cap and are now wondering where to get that large rubber o-ring, and the gasket? Well a garden water hose female rubber washer is a exact fit, and any auto store will have gasket material cheap just make your own gasket. Just make sure you scrap off the old gasket get it clean, use a little sillycone, ( i said a little ) just to hold the rubber washer and the gasket to the cap.
Say it went straight to the t-stat housing, then maybe the t-stat is bad. It's frozen closed maybe ?
Me for now i would pull the t-stat and replace it latter and close up the housing or leave the t-stat out for good.
Now start the boat it still overheating ? You have the idea now ? Keep going down the line till you find the obstruction, risers, heat exchangers ? Maybe a flapper / shutter fell down and is blocking the exhaust ?
Say you don't have good water out of the long hose from the transom, you could use a garden hose to back flush the hose.
Post back and let us know what happened.
