Ive got a older mercury outboard 50hp 4 cyl. Starts and runs great. Will not shut down with key. Just replaced starter and switchbox module. When i turn the key off it still runs. I pull the plug wires to shut it down it has no change when i pull the top 2 plug wires off but will shut down if i pull one of the bottom plug wires off. So its shutting down the top 2 cylinders and keeps running on the botton 2.
I pulled the black and yellow wire off the mercury kill switch and grounded it and still does the same thing. So im thinking my problem is in the engine area and not the key switch.
