"the plastic rod comes off wit
"the plastic rod comes off with the carb, remove starter for best access, remove carb. When you pull the carb the rod and plunger falls out of the choke solenoid, maybe someone didn't put it back in the hole.
The choke solenoid I believe is bolted to the front electrical mounting plate, which can be moved out of the way by removing the 2 9/16 stainless bolts on either side of the front plate.
Thats from memory, which could be off.
The solenoid can't be fixed, its just a bundle of wires wraped inside a housing and sealed. My guess is either not togeather correctly or no power to it when the key is pushed, (bad switch)"
