" running off the hose it runs
" running off the hose it runs fine,, put it in the water it wont run passed 2000rpm. checked the compression on both plugs,, its holding compression fine, im getting good spark from coils to plugs and from the plugs to ground. the only thing that i havent checked is the power pack,, would that cause a loss in power, and if so how would one check to see if the power pack is good or bad with a volt/ohm meter?
Thanx: Travis "
Thanx: Travis "
