Frank D Davis
I have a 1982 Johnson 150hp outboard. It is using an enormous amount of fuel. Like 6 gallons for 5 miles at 20mph on bass boat. It runs fine and Idles OK. Can see fuel on water and leaking from some exhaust areas but is not visibly leaking inside the motor cover area. Can this be a fuel pump issue. It appears the fuel has to be leaking into the crankcase because you don't see the fuel around the carburetors or fuel lines. Started out I just chalked it up to motor getting older but it has been getting worse and worse. any help appreciated
