1982 Glastron SSV177 Aq125a engine Volvo penta NEED HELP
alosse
Question-Why does my boat want
Question-Why does my boat want to pull left the faster i go the more it pulls left. If i let go of the steering wheel it will go left quickly.
"This is due to the "prope
"This is due to the "propeller torque". Adjust slightly to starboard (to the "right") the trim tab or steering fin (located in the bottom end of your outdrive, above the propeller) and test again. Repeat until the boat does not pull either way."
Thank you for that information
Thank you for that information.Thanks alot will try that and get back to you . Thanks again.
Would this be the exhaust outl
Would this be the exhaust outlet that you say to adjust??? Is this what they call a steering fin ?? Thanks.
Thanks alot for infomation. I
Thanks alot for infomation. I do have a 270 outdrive.Had no idea that turned but i see it does so i marked it and turned it alittle about 1/4 in from the mark i made as a starting point.Thank you again.....Thanks.
