1982 evenrude 75 hp post dec 25 2005
lm25tex
while i how had this motor in
while i how had this motor in the shop they rebuilt carb put new everything also still don't run right it on a 86 bayliner it sometime run good but it won't plane out it just keep the noise up and just boog down need help spent &1500 on the motor compresson is all 120 on all 3 cyl
"Greetings. Are you saying th
"Greetings. Are you saying the motor is racing but you are not going anywhere? If so, sounds like a bad prop hub. You can mark the prop hub, and mark the prop, run it, and see if the marks still align. If not, the hub is slipping & prop needs to be re-hubbed."
