I change lube in stern drive a
I change lube in stern drive and pump new lube up from drain plug with a pump till full. See i just put U-joints in. Now Ques is after i put new lube in till i see it on the mark on stick is this the only place gear lube goes in stern drive or is there another area to fill.I notice a plug above the plate that the fork lever is. Its a big plug. I look in there after puting lube in and i did not see any lube in this area.Is this a differant area where i am suppose to put lube in Too??? Need Help asap Thanks.
