Redrider6604
The boat it’s on is a 17’ deep v hull boat. On a good day it might hit 23 mph with two people. But it’s great for just cruising around for us. Last year we were out on the river and ran great. Had it off for a while we floated with the current. Started back up and idles perfectly fine. Went to go give it wot, it would bog down and it would try to open up but it just couldn’t. So got back to the ramp and took it home and parked it. Rebuilt the carbs once again thinking that was the problem but they were spotless inside but rebuilt them anyways using oem gaskets and stuff. Rebuilt the fuel pump and replaced all the fuel lines and the primer bulb to the tank. I have replaced all three coils last spring along with the ignition box also. Plugs are new and wires also. Has good compression on all three cylinders. I have even took the gas cap off while trying it and it didn’t help either. But it idles great in the water and if I throttle it up manually in neutral, it revs all the way up with no problems but when it’s in gear, goes fine till you try to go wot then it Boggs down really bad. Any help is greatly appreciated!
