"after doing it incorrectly no
"after doing it incorrectly now I need to take the flywheel off to replace a trigger assembly. There was a yellow plastic covering over the flywheel nut so I removed the screws holding the flywheel to the hub, took the flywheel off removed yellow cover, now I need to remove the flywheel and hub as an assembly. I have bought longer bolts to screw in the hub, I have a steering wheel puller but only 2 holes will align up, these are directly across from each other. Will I be able to use it this way, just dont want to screw up anything else. BTW the trigger has a burnt smell. Thanks"
