Thanks in advance for any recommendations!
Was on the water, took a few minutes to get start but once started the boat was was running great. No issues at WOT. Ran for like 30minutes and boat just dropped RPM and died. Tried starting again noticed a ton of fuel coming from the motor. Opened the motor and say a hole in the side (see pictures). Obviously motor is blown.
I do do have a couple questions. What could have caused the motor to punch through at that particular spot? What solution could fix it from happening again. What tell tale signs should I have seen before this happened? Is that spot repairable if welded up?
Im really trying to figure out if it's worth rebuilding or if it's just a heap of garbage now.
Thanks!
pic host
Thanks!
pic host
