1982 40 HP Mercury Compression
thebubba
Does anyone know what compression I should be getting from my 1982 40 hp Mercury Outboard? I am getting around 95 PSI from both cylinders, but I don't know if that is good or bad.. They are close in PSI to each other, but it seems a little low. Thanks for you help.
Ok, I just wasn't sure if that was way low. Some of the mercury engines have 145 PSI, but I guess this model is lower. The engine looks brand new inside and out. I will continue my work of rebuilding the carb, replacing the impeller, changing the water jacket gaskets (they leak) and installing it on my 16" Alumacraft. Thank you for your responses.
