" Hi guys,
I am disassem
" Hi guys,
I am disassembling a 1982 35hp Johnson in order to fix a jammed and broken shift linkage under the power head in the lower section where the drive shaft is. The gasketed connection there is solid and there is little space/leverage available.Does anyone have any tips to separate the connection between the power head and the lower section? Is the drive shaft holding things together since all 8 bolts have been removed. Thanks a lot............ "
I am disassem
" Hi guys,
