astroglass_81
"Hello, I am new to this site
"Hello, I am new to this site and find information here very informative. I just aquired an 1981 Astroglass 15' 6" Fish & Ski, with a 1981 Mercury 90 HP Outboard. I really don't know anything about the history of this vessel, and have never heard motor run, but does not look too bad. With that said, Compression on 3 cyls is 135, 2 cyls 132, other cylinder 128. Drained grease out of foot (no water-yipee!), replaced water pump impeller and checked spark on all cylinders. All cyls were good at 1/4" gap except #5-dead. Swapped (+) coil wires between #5 & #6. #5 coil then fired, #6 didn't. Is the switchbox dead on that cyl only? and I also found ground screw connection loose for #5 coil. Would that have caused switchbox to fail on that cyl? I know very little about outboards, but have been an auto mechanic for years. I have never heard this motor run. Has been sitting atleast a couple years. Just removed gas tank, going to clean crud out of bottom and install a new sender. Then going through carbs, fuel lines, and maybe fuel pump, (gas very stale) Any help would be appreciated. Thanks"
