1981 Mercury 40 HP 2 Stroke
BassTracker81
I have a 1981 Mercury 40 HP on my 81 Bass Tracker. Narrowed it down to a bad trigger that is causing weak spark on the upper cylinder. Because I can't find a trigger, I'm now stuck debating what I should do. I can buy the same motor and use it for parts. The guy says it runs but needs a throttle cam actuator. I can also buy 2 1984 Mercury 60 HP and replace the motor altogether. These 2 motors both run. There is also a 2000 Johnson 25 HP that runs. Anyone have any suggestions on what I should do with the motor I got, or any input on the motors I listed. If anyone has a favorite motor I should look for id be open to that to. Thanks guys.
Try Tim's Outboard in Hackensack MN they should have what you need. Fast and cheap. Shipped quickly, sometimes same day. 2186822331.
