Ok guys as you may see I'm new here and to the whole outboard scene. This is my first boat, i have a small 12' plastic Jon boat with a 1981 Johnson Outboard 6HP that i bought from a friend. Here's my problem, when i bought the motor i obviously made him start it first, it was out of the water and he sprayed some starter fluid and started it on the second pull. So i bought it. Now that i have it in the water its a lot different. I manage to start it on full choke after about 5-6 pulls. Once i get it started i have to leave the choke on and the throttle can only go about halfway or it will die. I ran it for about an hour with the choke all the way pulled and the throttle about halfway. As soon as i try to put the choke in, it runs for about 5-6 seconds then dies. Another thing i found weird was that with the choke pulled and the motor in neutral i can give it full throttle without it dying. Anyone know what could be the cause of this whole issue?
