This is my parents boat that I'm trying to get running reliably to sell it. It has a 1981 Johnson 70 hp. The last time it ran was 13 years ago.
Performed compression check and from top to bottom it was 125, 125, 120sih.
Initially, there was no spark and that was isolated to the power pack. Replaced and that resolved the spark issue.
Carburetors were cleaned with the exception of the bottom jet (didn't know it was in there).
Starts, but ran poorly. Lots of missing and back firing.
-- Did continuity check of plug wires & two were failing. Repinned the ends and now the continuity is good.
-- Found the bottom jet and cleaned and unclogged the lower jets.
At this point, it had a pop. Then it developed into a pop with a backfire. (sometimes with a nice smoke ring)
-- Re-cleaned the carbs and replaced needle and seat.
-- Replaced the plug wires.
All this and no effect.
Rebuilt all the carbs. Removed welch plugs, replaced all gaskets, made absolutely positive that all passages including upper jets are clear.
-- NO effect, still pops.
While the last time it ran, I pulled the plug wires to see what is up with each cylinder.
-- Upper wire pulled. No change in running condition.
-- Middle wire pulled. Engine died.
-- Lower wire pulled. no change in running condition.
When to store and bought a spark gap tester, set at 7/16".
-- All coils produce nice blue spark across tester.
Checked coils with multi-meter and then all test with consistent numbers between primary and secondary coils.
So back to the removing the plug wires when the the engine is running. Any thoughts?
I'm kind of at a loss here with this thing and tired of replacing stuff without any effect. Tomorrow I'm going to swap the 1 & 2 coils and see what is up.
Any other things that I should be doing? I'm getting pretty frustrated with this dad gummed thing. Most posts I see about issues like this, there is no resolution posted about the issue.
Thanks in advance.
Thanks in advance.
