1981 Johnson 7 12 hp SeaHorse
D
Darold Smith
Guest
Just got a 71/2 seahorse John
Just got a 71/2 seahorse Johnson at a auction
and need to know oil to gas ratio.
" Darold,
You might want to p
" Darold,
You might want to provide the model number of that motor and see if there is a different mix needed. Some of the older small OMC's required a 24:1 mix instead of the common 50:1 used on the majority of the 2-stroke outboards. If your motor requires the 24:1 and you run it at 50:1 you risk damaging your motor at worst and having the motor run only for a few minutes then dying due to overheating created by insufficient lubrication. "
"Darold.... All of the OMC out
"Darold.... All of the OMC outboards in the 1981 year range used a 50/1 fuel/oil mixture.
Joe
