1981 JOHNSON 50 1 CYLINDER
blue_blade
If I swap position with the re
If I swap position with the red wires dosent this swap the fireing order of the coils.Orginally my bottom coil went to top spark plug . And my top coil went to the bottom plug my motor only would run on bottom cylinder . I swaped the red wires like i said . And i assumed it changed fireing order so i also swaped plug wires so now then my top coil is going to the top plug and bottom coil is going to bottom plug. I started the motor with a good bit of choking and it started on the top cylinder and ran decent the bottom would not fire and start . There for wouldnt that make my bottom coil bad ? Because I seem some how to make both cylinder run with the top coil but the bottom coil will not let either run .
