1981 EVINRUDE PRIMER
royboy
My engine has a primer system
My engine has a primer system in place of a choke. Is this better than a choke ? How does this function. I don't think mine works.
"yes,..much better.......it is
"yes,..much better.......it is simply an elect valve...it opens and allows fuel pump pressure to go to intake or,should be,in your case,to bypass cvrs.."
Should it squirt gas when the
Should it squirt gas when the ign switch is pushed in or does the engine also have to be cranking at the same time to work the fuel pump to make it squirt?
"eng needs to be cranking,..or
"eng needs to be cranking,..or,...squeeze fuel primer bulb/push sw.....or turn red valve,squeeze bulb."
"I don't have a red valve.
"I don't have a red valve. It does have a pointed lever that turns for manual use, whatever that means."
manual if you have to pull sta
manual if you have to pull start or have a problem with the run function.
just leave it on run and treat it like a choke.
It's black but I think I h
It's black but I think I have that problem solved. It seems to work ok now that I have learned how it functioned.Thanks for everyones help. I do have a intermitant ign prob also (See new post)
