Ryan Ayres
5 days ago: I just bought my first boat which is a 92 Sea Ray with a 1981 E90TLCIM 90HP. I have gone through many posts and many do not share success stories. When I Idle pt on the muffs it runs fine and idles up and down. When I first put boat in water it starts right up and got out of the no wake zone from the ramp and kicked it up no problem. Went a little down the lake and friend left something at the dock so we went it to start it back and it will start and idle. Put in in gear and idles. throttle it up and dies. Had to restart like 4 to 5 times and it will finally throttled up and made it down the lake to fishing hole. shut motor off for about 45 min. Start it back up idles no problem. Put in gear and throttle up and dies. Same thing starting it back up into idle and when put in gear it idles until we ease it into throttle and it dies. Restart trying to throttle up 4 to 5 times and then it finally goes.
Yesterday: Changed Spark Plugs, New Fuel Pump, New Water separator/fuel filter, New inline fuel filter.
Took it out today and same exact thing. First put into water and got out of wake zone and throttled up no problem. Get down the lake and shut off engine for 5 minutes. Start it back and idles. Throttle it up and dies. Restart 4 to 5 times trying to ease into throttle and finally get it going. Sometimes I have now tried to rev it up not in gear and it dies as well. Just keep at it restarting and once I get past the idling up I put into gear and it may throttle up. Also tried squeezing the primer and it is hard and pressurized. You cannot Squeeze it when it has been running and pressurized. It seems fairly new and I have been able to pump it up yesterday and many others in driveway until it gets hard and pressurized. I see the fuel pump up in inline filter.
Once it is actually going I have no problems whatsoever with throttling up and down and the boat runs fine. It just seems to start after the motor is shut off and restarted. I may be onto a carb rebuild next. Sucks for my first used boat to have to go through this. Any help would be appreciated.
