motormanhbg
I have a 1981 Evinrude 9.9 prop outboard I just rebuilt for a friend of mine. I usually don't have any troubles rebuilding these but the main
drive shaft will not turn the lower end unit no matter what I do. There is a spring with two ball bearings that go between the drive shaft/drive shaft pinion and the shifter clutch dog. Is there a trick to put this into place or am I installing it wrong? I put it in and there was spring in the driveshaft but then I lost it and both spring and ballbearings are no longer there. Am I installing these wrong? I there some kind of trick to this? Any help would be greatly appreciated. Thank you!!!
