I have cleaned my carbs, have good compression....the engine idles fine, after it gets on a plane it builds up speed to about 38mph and runs good from 15-38mph. I checked the spark and it jumped the required 1/2 inch. When I was out today I pulled the plug wires one by one. Each one affected the engine at idle. However, after pulling off the wires on cylinders 2 and 3, the spark gapped from the coil to the engine block. Also, when testing on land I noticed the spark jumping from coil to block when I had the spark checker to far apart. Does this mean Ihave bad coils? Wires? Any comments are appreciated. When I say poor acceleration , It will barely run for about 30 seconds then slowly start speeding up. I have tried squeezing the fuel bulb but did not do anything and tried hitting the choke and that made it bog. This motor is on a 13.5 little bayliner mini boat. It also has a 17 inch prop so it shoud have plenty of spunk. I am stumped.
