So as you can tell from the title I have a 1981 25hp Evinrude and it is having trouble shifting. Basically, I can shift it from forward to reverse and back again but it does not slip into or stop at neutral in between.
This problem arose after having the lower unit disassembled to replace the gear-case seals. Last season I replaced the shift rod lever and after putting everything back together it did not shift as smoothly as before my work.(it would only go into neutral from reverse) This time I seem to be having a similar problem but worse.
Here are my thoughts on what I can think might be the problem. Maybe one of you will have some suggestions or can give me some feedback on my basic understanding of what might be going on. I am dreading taking the gear-case apart again. I just want to go fishing!!
I think that the pivot pin is seated in the shift lever correctly. Otherwise the motor would be stuck in one gear or the other and I would be unable to shift... right?? Also it doesn't seem as though anything is loose and rattling around.
While putting everything back together I took time and care in making sure that the little balls and spring(forgive my lack of correct terminology) were loaded in the prop shaft and lined up correctly with the corresponding slots in the clutch dog. I am about 99% sure they are lined up... but maybe not. Though, the slots seems to be there for the sole purpose of stopping the clutch dog in neutral, so maybe that is my problem.
Every time I drop the lower unit I have trouble getting the shift linkage reconnected. For whatever reason the shift rod has trouble sliding into the linkage. I usually end up having to grip the shift rod with pliers to keep everything lined up and to keep from pushing the shift rod down and into reverse and therefore out of reach of the upper shift rod. Maybe not having the linkage hooked up in exactly the correct way could cause the motor to skip neutral?
Anyway that is my problem... well one of them anyway. Thanks in advance for your replies.
