1981 35hp johnson short shaft
dynomite00
"some back story. sucked sand
"some back story. sucked sand into water pump. replaced pump ran good for 3 hours then died, put new plugs in and wasnt spitting water out. replaced the thermostat, wouldnt start easy and wouldnt stay running easily, but it was starting to spit water again(only after i used the hose and the clamp water system to start it, in a garbage can it would not spit water out.) my question is, is it carbuetor? water pump? what could my problems be?"
