Last week I was out running the engine in full throttle and the engine would throttle down on its own and die out. It sounded like it wasn't getting any fuel. This happened a few more times on that trip. When I got home checked all the fuel lines, put some sea foam in the fuel and checked the spark plugs. I pulled the cable off one plug and it would run fine, and when I did to the other one it would barley run at all. Could it be a coil shot? I was also thinking the fuel pump might be bad also. I had it out 2 more times after I messed around with it and it ran good. The last time it ran good until on the way home it started to die down again. Once it got to the boat launch I had a hard time starting it to get it on the trailer. My first thought is that the coil or fuel pump has has something to do with it. I’m no expert thanks for any information.
