Newby here,
I have encountered this problem over the last 2 summers trying to resolve with replacing parts,
Fuel system- have replaced with new fuel line,fuel pump,filters and new carb.
Ignition system-Have replaced battery,plugs,wires,coil and electronic ignition,cap and rotor.
Problem- After 20 to 30 minutes of cruising the boat starts to to act like its not hitting on all cylinders, it will eventually just not keep itself on plain. it will idle and rev fine when not under a load, but will not pull it self back to plain unless it has cooled down for several hours, then it will run fine again for 10 to 20 more minutes and act up again, Seems to me it is a heat related issue.
I'm beginning to wonder if I'm getting some voltage loss from the coil to the distributor!
Please Help,I'm at my wits end and about ready to sink it!
