I just bought a Mariner 4 hp, 80s model, that ran good at the time of purchase. I test ran it several times once I had it on my boat and it started OK, not great but OK, had a little bit of trouble shifting gears, but it pumped well. It had a nice strong telltale. The first time I took it out I started it, all Ok, pumping great, motored out and about a minute later I looked back and saw that it wasn't pumping. So I shut it off immediately and got a tow back to the dock. It won't start now. I just want to know that I couldn't have possibly wrecked the motor in a minute of running it without it pumping water. I also wonder if the previous issues I was having could be the reason it's not starting and that the pumping is an unrelated issue (likely the impeller.)
The issues I was having before were that the motor only wanted to start at higher speeds, ie I would have to set it above "Start" on the throttle in order for it to, well, start. It would also not always shift into neutral when I went to shift from forward. It seemed stuck. It also refused to start with the choke on it. Would this be a carb related issue and would this be a reasonable explanation of why it is not starting now?
I really know nothing about motors, I know how to take care of one that is running good but when things like this happen I'm pretty lost. I'm still learning. Thanks in advance.
