Lucas Ziegelbauer
hey guys i know a few people have had this problem before but i just got a 17 foot runabout for dirt cheap i hope if the repairs are minimal i got the engine running recently fresh gas fresh oil and cleaned and set the points as well as changed gear oil the problem imhaving is when i start to accelerate past 1400 rpm i get a very rapid increase in engine temperature maxing out gauge within 1 minute or less once back off temp drops in smooth and fast manner
and holds steady at 145 degrees
the engine water pump is fine and water is definitly being circulated properly the ball gearsare getting lots of water and
the water is exiting the propller normally i dont want to replace the outdrive impeller if i dont need to so if you guys have any tip on flushing the water system in reverse id like to try as there are lots of rusts flakes
thanks for your inputs
