I recently purchased a 1980 mercury outboard. The PO stated that he just had it running, but I no longer believe this.
Long story short, I think I've narrowed down the problem to the trigger and/or stator. I dug in, removed the flywheel and the stator, and attempted to get to the trigger plate, but I'm stuck with removing the attachment on the flywheel to remove the trigger plate.
Take a look at the attached picture. How do I remove the red plate above the trigger plate? I applied enough force with a flywheel puller to pull anything, but I can't get it to move. Even soaking it with pb blaster hasn't helped.
Any suggestions will be much appreciated.
Thanks!
https://imgshare.io/image/Sy6MH
Thanks!
