lovethatblackmotor
"Water pump impeller failed bu
"Water pump impeller failed but motor was shut down very quickly. Impeller replaced. Bottom 3 cylinders 150 pounds compression and spark plugs look like new. Top cylinder 135 pounds compression and slight coating of grey flecks on spark plug. Motor starts and runs like always. Questions (1)Can I run this without further action, and (2)What are the chances that work will have to be done to that cylinder...and if work is required, what would it involve and is it something that a mechanically inclined person can do themselves? Thanks in advance for any help!! BW PS - There is a fin (or pieces of a fin) from the old impeller in there somewhere. Should I be concerned about that, and is there anyplace I can open up easily to get them out?"
