1980 johnson singer 75
Boatman129
got a 75 johnson stinger having problems with the lower unit as i am getting water into the gear case i put in o rings and gaskets in... what could else this be?? and there is water getting behind the propeller too!! could this be the water pump??
would like some help thanks
I believe you have asked about this before , maybe did not like the advice ???----------Run and hurry to your local outboard repair shop.-------They can pressure test the lower unit to determine exactly where the leaks are.
