I have a 1980 Johnson 70 seahorse i'm having problems with. it runs good with the ear muffs on, i can put it in foward or reverse no problem. but when i put it on the lake or in a barrel of water it bogges down and wont run at all. i have checked compression all 3 cylinders have 130-135 and all 3 have good spark. water pumps out really well with muffs and in water. next on the list is carburetors...tonight me and my dad were messing around with them, before we took them off we had the air intake manifold off so you could see all the carbs on the engine. we had the engine started and he sprayed a tiny bit of carb cleaner in the top one and it reved the engine, he sprayed into the middle one and it reved the engine....but when he sprayed a tiny bit into the lower carburetor the engine died insteantly. so we started with that one took it off cleaned it replaced gaskets and float and what not. we put it back on and it did the same thing . anyone have any ideas why its doing this. or why it dies if we spray a tiny bit of carburetor cleaner into the lower carburetor?? or have any suggestions on what we should be looking for...we are planning on rebuilding all 3 carbs this weekend. Thanks in advanced for any help. and hello!! i'm new to these forums.
