My son purchased this 80' johnson 15hp motor (J15RCSD) for 40 bucks. It didn't run when he got it. I checked compression, it is 70 on both. Replaced worn pinion starter gear. I had to replace the broken cam follower, set it where the roller touches the mark on the cam plate and starts to open the throttle plate. put new fuel pump on it. new plugs. it has good spark, will jump 7/16 with a good pop. cleaned carb the first time and then got a kit and rebuilt it completely the second time. I adjusted the idle needle screw backed it off 1.5 turns, then adjusted it in by 1/8 increments till it started coughing then back out 1/4 turn. Now it will start with the throttle opened mid to wot. seems to run pretty good now. My question/problem is that it will not stay running at idle unless the cam roller is touching the mark on the cam plate, if the throttle is decreased any lower it dies. In advance, thanks for all time and effort in assisting me!!
