1980 johnson 115
"when i start the motor it see
"when i start the motor it seems to run rough and with a lot of smoke, then i bring the boat to step and then back down and no smoke even when the motor is warm. also rough lower rpm running , very smooth in higher rpm. suggestions for adjusts, she is really drinking fuel as well"
"sounds like its rich at start
"sounds like its rich at start up from too much choke,have you done a carb rebuild lately.
they do consume a lot of fuel/quickly,hope you have a tank bigger than 6 gal"
"thanks for the quick answer..
"thanks for the quick answer... I'm savy with engines, but a little green on outboards. I guess I need to find a manual... any suggestions on where to find em cheap/used .....
thanks...
driver of an old boat"
