I have a 1980 evinrude 35hp electric start, remote steer motor. The motor has 120 psi compression on both cylinders and has good white/blue spark that will jump a 7/16' gap. The motor will run great on my boat (15' sea nymph deep v) with no issues if I am alone in the boat. If there is another person in the boat it starts to act like it is starving for fuel as it is about to come on plane. The motor will surge or bog down and I can only go about 7 mph before it will act up.
If I bump the key in to activate the electric choke a few times it will clear up an take off on its own like nothing is wrong and then run fine. When it is bogging down squeezing the primer bulb does nothing.
The boat has new Primer bulb, fuel lines, fittings and fuel tank. The carb and fuel pump have been cleaned and rebuilt.
Any ideas a to what would cause it to run fine with one person in the boat and then bog down under a heavier load?.
