I know there have been a number of issues like this discussed in past but I'm stumped. I have owned many of these & took this one as a project to learn more but need some second opinions please.
Here's the basic facts: Motor will not start & fires only occasionally (on 5th pull) for 2 seconds & only with a bit of gas sprayed in plug hole. I have tried to isolate the obvious issues to narrow it down. At first I though fuel issue & carb was disassembled & cleaned. Also the tank, fuel line & filter. But since minimal to no fire with gas sprayed in plug hole, suspected electrical.
- Coil primary winding seems to check good on the meter. / no visible cracks or damage to coil
- Secondary winding at the spike about 400 & 400 at the plug wire end ( digital Fluke meter) / unexplained using analogue meter shows 280 at plug end.
- Plug wire cut back 1/3 inch for fresh copper at the spike
- Point set at .020 (as best as I can )
- Spark tester shows there is spark at the plug / I think this should indicate a good coil & point ? spark intensity unable to determine
- New #1 gas & 50/1 mix
---- Just the odd "cough" (that kind that gives you hope) but no actual start:
All ideas/comments appreciated / Thanks
