Just overhauled engine and has good, equal compression on all four cylinders. All four cylinders are getting a solid spark(jump 7/16" gap). Motor is running 4 degrees BTDC at 750-850rpms. The problem I'm having is getting the idle set correctly. Right now I have the throttle linkage adjusted so far that the idle adjustment screw is maxxed out and is still half an inch away from the block. I had to adjust it so far in order to get it to idle at 750-850rpms(In a test tank). If I back the linkage off any then the motor stalls and dies. The issue is that it shouldn't have to be adjusted so far in order to idle. I'm wondering if I possibly have a fuel problem that isn't related to the fuel pump or the carbs? Fuel pump is rebuilt and works perfect(pumping primer bulb changes nothing). The carbs were also rebuilt and cleaned very meticulously. Each and every single jet was removed and cleaned, all passages blown out with compressed air, etc. I'm curious about this fuel recirculation system and if there is a way to test it? It has all new hoses and all the check valve w/screens were cleaned out and tested during engine assembly last week. I may be WAY off with this guess and that's fine, I just want to get my motor running properly so I can take it to the lake and do the proper engine break-in procedure. Also, this motor has never ran since I've owned it. Bought boat, motor, and trailer as a project last summer and the motor is all that I have left to complete. Therefore I have no idea if any of the settings were correct prior to me purchasing the boat. I have an OEM manual as well and followed the instructions for setting the idle but it just didn't work out like it was suppose to. Any help or advice will be greatly appreciate! Thank you!
Thanks,
JD
Thanks,
JD
