1980 9.9hp evinrude starting issues
Outdoordude
My 9.9hp evinrude outboard will start using ether and run at top speed and idle/troll just fine. The motor will not start the next day without help from starting fluid. I have injected seafoam in the carburator extensively without luck. Do I need to pull and clean carburator? Is there other option without pulling carb as this seams like a difficult job. I have watched utube for pulling and cleaning carb and maybe outside my skill level.
For starting issues make sure you have the throttle advanced completely to the neutral stop. Ignore labels on the throttle's twist grip and turn the throttle counter-clockwise until it gets stopped. Pull out the choke and observe that the butterfly actually closes on the carburetor. Some will still click even when the butterfly is still open (not engaged). If the motor does not start with that verify the link and sinc is set up properly. There is usually a line or arrow indented on the throttle cam (piece under flywheel that pushes on the carb roller when you turn the throttle twist grip). That line/arrow should be in the middle of the roller JUST as it touches the carburetor's roller. Also make sure there is no wear play on the carb's roller and throttle butterfly. The throttle's butterfly on the carb should also JUST start to turn when throttle cam pushes on that roller. You can observe this by looking for movement of the hindge for that butterfly on the starboard side of your carburetor.
